Front Camber problem...
  Clio 182 cup
Played around with camber today on my coilovers after fitting my ARB bushes,
i think i went a bit over the top and put it on max, i no it was silly but though id try it and it rubbed on the adjuster rings on the coilovers, and drove like a bag of s**t
any one ever had this problem before ?
or would just advise plying around with the camber until im happy ?
cheers Dan
Ricardos
  LY 200 EDC
Playing with camber? What are you using the car for, dedicated track only car or b road blast, work car?
Personally, i'd get it set up on a Hunter machine (IIRC) ride height set, -2 degrees negative on the camber
  182cup & 172 racecar
cheers Dan
I've highlighted your problems.
  Clio 182 cup
This is what I'm going to do seems the best idea going to get it booked in tomorow.
