Front end knock / rattle
Car  Clio 172mk2
Ok recently my car developed some knock / rattle happens in a straight line , faily even road. At low speeds as well as 50ish.
I had a look few weeks ago and notices track rod ends where knackard so repaced these, then noticed the drivers side driveshaft inner boot was leaking so replaced drive shaft with a new one (renault).
But im still getting the knocking. Im off to jack car up tomorrow. But what will it most likely be top mounts worn? some one mentioned antiroll bar bushs?
The noise when driving does sound higher up, but how would you check the anti roll bar bush`s if it was the inner ones
thanks in advance
