Front Fogs Wiring to Battery
  Corsa D
Hi All,
Help seems great on here so thought Id ask my own question :approve:
I currently have an Mk2 ph1 Clio Grande and fancied the look of fogs on the higher versions so I brought front fog kit wiring/stalk/chips the lot from Renault.
I’ve fitted everything with success with the help of drawn instructions book that came with the pack but there one part where I’m just baffled when it comes to powering the lights.
I’ve connected the black earth wire and red live but there 1 black plastic coated that spits into 2 and where the instructions aren’t clear where it goes it just gives rough area.
Has anyone connected this kit successfully or know there this wire is to? You would be my savour! :D
Many Thanks
Tony
  Carrera 4S. Clio 172. M5
Can you copy and paste the wiring diagram and I will have a look for you.
Where is the "rough area" you mentioned ?
  BMW 320d SE
Maybe it wires up to the side lights, so that you have to have sidelights or headlamps on for the foglamps to work?
