front knocking.
  GDI 227bhp ITB`d 172 cup
hi all, i`ve got a 172 cup, done a few mods 2 it but seem 2 hav a knocking noise coming from the front suspension on full lock and under braking it feels like the front of the car moves about abit.:(
i`ve had full fk coilovers with koni dampers al round(lowered about 60mm alround cause i`ve took the back seats out and nearly on hardest setting),front and rear upper strut braces,rear whiteline adjustable anti-roll bar (worth every penny - highly recommend getting 1) and hi-spec 300mm 4pot brakes plus other mods not 2 do with the suspension.
if i fit a lower front strutbrace do you think it wud stiffen up the front end or be 2 stiff?? and wud it stop my suspension and braking problems?? thanx 4 any help you can give.
I have Koni and have the same problem from front driver side bottom near the wheel area.
I had FINALLY ordered the suspension arm and will change it to see. I guess it is the ball joint problem.
Well, I had changed the top mount but that did not work.
