Fuel Pipes
Barron
Car  Turbo S,Exige,R5,182
Looking at trying to get this engine started this weekend the problem is it doesnt actually have any fuel pipes atm. Has anyone got a piping diagram or can give me a quick run through of what goes to where etc?
Another thing, is the fuel pump next to the actual fuel tank?
thanks for the help
Carl
Fuel pump you can get to easy remove/tilt the bottom of the back seats and under the black cover with the wires going to it you'll find the pump and pipework.
Depending on car engine you'll have a feed and return lines.
2.0ltr (172 cup) engine fitted to a ph1 1.2 clio atm
have you swopped the fuel pumps as well its not difficult (asuming you have got or made the tool for the locking ring) else you might have trouble as the ph1 has a return line the cup doens't.
well atm im just trying to get the engine running in the ph1 to make sure its ok after the compression test. In the end the engine will go in a ph2 1.2 16v.
I don't see why go to the effort of fiting it then only to take it all out.
