Fuel pump
Car  1.2 16valve sport
Hello i have a mark 2 54 plate clio with a digital dash.
The engine im running is a mark 1 F7R. But im currently running the 1.2 16v fuel pump.
I have a 172 phase 1 fuel pump which ran dial not a digital dash.
However both have 4 wires from the pump, Live, Earth and im guessing two signal wires.
Does anyone know if i wire it up to my digital dash will the potentionmeters be the same and the dash will read the correct fuel Level
Thankyou for any help in advance.
Reason i need to change the pump is because i require the fuel return for the f7r which the 1.2 16v engine did not have.
Hi,
We run the Digi Dash, and the tank under reads, as in i do50 miles and it still says its full, when i get to <10% its really 1/4 full ;) That was in mk mk1 valver.
On doing the 172 as we speak having issues with this tho, Ill be running the wires tonight see what happens
