Fuel Tank Change (Weight Maybe)
Got a problem with the fuel tank and will need it changin soon.
1. how much is one new from Renault for a MK1?
2. how easy is it to do?
3. Any one fancy lending me a hand or know someone will do it cheap?
speak to infinicar, mat brown or local reno breakers to get a replacement
easy enough, just got to unplumb urs and replumb new un
ur a little far from me, but there might be someone local wiling to do a little work?????
i jus knew u had obviously changed urs so thought u could help me out
Hows the tank help in place?
might pop down scrappie or as u said speak to Matt
obviously there is filler neck diffs on 16v and willy because of the reserve tank.
but the main tank might be exactley the same.
just empty it before u start removing it (if u do it urself)
leave the fags to after u finished and washed up tho:D
whats happened to urs?
theres a split at the top so ne more than £10 is starts leavin a puddle!
could be jus a hose at the top i was told but dont wanna take chances and lowest quote ive found for a change over was £85 which i would rather do it myself
jus a case of gettin under the car and unbolting it as u said, might av to get a haynes manual out
could always get one like urs ;)
ah thanks lunner, fuel pump will be diff as well
but dont get confused with main tank capacities and the extra reserve tank a 16v/ willy has
yea go look at Riplashs then
tut tut, a one track mind youve got ;)
You sure the extra reserve tank on a Williams is that big?
My light came on.. and 30miles later, it was stopped.. not going anywhere.
most of the reserve tank fuel pumps stop working
but when the light comes on, u can hear the reserve fuel pump pushing the fuel into the main tank (if its working that is) last about 10 secs
