197ff, 172
Hi All
I've finally got around to getting my 172 ready to go back on the road/track days. I pulled out the carbon canister to make room for brake ducts and got thinking that it would probably be a good idea to use some sort of fuel vent to let these fumes out. So I searched the forum and it seems that if you simply blank the vent off the tank starts to pressurise and some people suggested using a 1 way vent to let the gas out. But then when I was looking at vents it seems that some breathers (mainly motorbikes) vent air in to compensate for the fuel level decreasing and creating a vacuum!
so does the tank get pressurised because of a build up or is there more likely to be a vacuum? To be honest I don't fancy either scenario.
any suggestions on what to use would be appreciated but needs to be cheap because the car is a bit of a money pit at the moment
thanks in advance
Kyke
thanks in advance
Kyke
