Fuel vent/ carbon canister removal
Car  197ff, 172
Hi All
I've finally got around to getting my 172 ready to go back on the road/track days. I pulled out the carbon canister to make room for brake ducts and got thinking that it would probably be a good idea to use some sort of fuel vent to let these fumes out. So I searched the forum and it seems that if you simply blank the vent off the tank starts to pressurise and some people suggested using a 1 way vent to let the gas out. But then when I was looking at vents it seems that some breathers (mainly motorbikes) vent air in to compensate for the fuel level decreasing and creating a vacuum!
so does the tank get pressurised because of a build up or is there more likely to be a vacuum? To be honest I don't fancy either scenario.
any suggestions on what to use would be appreciated but needs to be cheap because the car is a bit of a money pit at the moment
thanks in advance
Kyke
I removed my carbon canister, the other night.
Blocked the top breather with a short M12 bolt and jubilee clip. I taped the wire up and cable tied it out the way I was a bit unsure about what to do with the tank vent pipe, so I followed it half way along the underside of the car, tucked it away and cable tied it.
​Gaz.
I've just realised the tank probably has a separate breather to let air in. Yeah I think as long as its secure just tucking it out the way should be alright. I was thinking about trying to get it back up toward the filler neck area.
Did you remove the solenoid bit altogether gaz? I read somewhere that it will throw up a dash light or limp mode
No mate. I removed the canister and bracket. Everything else is still there but neatly tucked away, just incase it starts to play up, I can refit without much work.
