fuse keeps popping
Car  Clio sport 172
as soon as i turn the ignition on it blows the fuse and the injection warning light comes on i have disconnected the fuel pump and it still pops the fuse disconnected the coil pack still pops and all 4 injectors have been un plugged and still pops ive followed most of the loom about and checked for breaks in the loom and even earth straps i cant think of anything else to do any suggestions??
Cheers Carl
Sounds like an ignition live on that circuit going to ground, you have covered all the components on that circuit by the sounds of it, ideally you need a wiring diagram just to make sure you haven't missed anything.
Thanks a lot for your help mate I followed the wires more today in the day light and I found that the lamber sensor wire had split so unplugged it and turned ignition on and the fuse did not pop so replaced the sensor and it seems to be fine now been for a drive and no miss happs so far so fingers crossed the problem is now solved.
Cheers Carl
