FuseBox Wire and Alternator "white" thing.
  Hondata'd EP3 Type R
Hi, I've recently purchased an optima yellow top and some pimp battery terminals. However, I cannot fit the postive battery terminal as the wiring from the fusebox is too short, So I have had to use the stock
(ugly) Battery terminal.
What would be the best way of extending these?, I've tried to trace them into the fusebox but they are part of a loom?
Also, The alternator (this wire is long enough) Has a kind of white block attached to in the middle of the wire, Any ideas if i need these? OR can i cut it off and wire straight into my terminal?
thanks
