gaz fully adjustable coilover problem, help.
Car  clio 182
hi i bort some coilovers for my 182 and had them fitted and they seemed perfect at first but rescently the front left one makes a springing noise and clunks more when going over bumps, they have covered less than 600 miles. i checked them both and ther both set the same height, the only thing i noticed was when raising the car on the jack the left one came loose of the top seating and when i lowered it i had to make sure it went back nd sat correctly, the right didnt seem to do that. they are both sat happily but one makes odd noises. i havnt touched or fidled with the damping, could it be on a bad setting? any advice would be great, thanks
I had a similar problem on my old 172 after first fitting my old gaz golds, turned out one of the springs hadn't seated properly.
How old are theses? have you contacted Gaz?
about 2 month if that, i had a similar problem on the back and turnt the spring 180 degrees and it fixed it but ive tried turning it round a few times on the front but doesnt seem to help, i could give gaz a call see what they say
