Gearbox 172
  172, Westfield
Any recommendations around the West Mids for gearbox experts?
Had a couple of mechanics listen to a whining noise and they say its diff / gearbox and either way the box has gotta come out to see the cause. Rang a few places and best so far is Four Ashes Renault specialists - they quote £300 plus VAT for labour to get box in and out. On top of this will then be costs relating to whatever is causing the problem.
Any other places to try?
  Megane 225
On my old 172 it was making weird noises and knocks from the box. Ended up being the slieve on the driveshaft where it connects to the box, it has loads of splines in it that had worn away. May be worth pulling off the passenger driveshaft as the part was only a tenner (they don't list 1 for a 172, but a megane 1 is the same)
  172, Westfield
I don't know what's wrong with it yet - Got a leak and this whine that changes when clutch dipped. Assume it might be a rebuild job but depends on what's found.
How much is rebuild all in?
  Lionel Richie
well depending what's up with the box all in (worst case) with a new clutch off the top of my head is sub £600
  172, Westfield
Cheers Fred - Not as bad as I envisaged!
What's turnaround on something like this? What's your availability for this kind of job?
  2005 Nissan Navara
Where you working these days Fred, out of intrest? Or are you still at Yozzasport?
Sorry to go off-topic lol!!
  172, Westfield
well I'm trying not to use it much at moment but as my only car I suppose it's something that needs looking at sooner rather than later. So ideally as as soon as
  172, Westfield
Got an idea as to availability at yours then Fred? Would I be looking at say a month before it could be looked at?
