Gearbox question
It will fit
However check to see if you have a speedo output in your car box (depend if you have ABS or not) if you do and the other box donesn't then you won't have a speedo if you fit the box.
ABS meaning anti lock brakes? Im confused. My car has ABS, the gearbox is from a slightly newer clio so surely it would have ABS too?
Yep ABS is anti lock brake.
Always check for the sensor I've seen a car with abs and the gearbox sensor on a none RS before.
So if it turns out that I wont have a speedo, is there any way I could get this fixed? Or would I have to get another gearbox?
Not sure what you mena if you r car doen't have a spedo then won't matter you can use any gearbox. If you have one and you want to keep your speedo working and milage then you need a gearbox from a car with a speedo sensor.
