Car is still pulling hard right under braking after fitting 4 pots. Changed all the hard lines to copper from the master cylinder, changed all the flexies braded on the front OE on the rear. Fluid transfer seems fine when pressure bleeding the system. Calipers pistons and slider are free. Even with OE brakes the car was pulling but left not right, new discs and pads on the rear as well.
Anyone got any ideas? What components does the cup have on the braking system? Master cylinder, ABS module etc...that could be causing this issue?
Thanks in advance, if I miss out and lose money on another track day cause it's not ready again then it's getting sold on the cheap or I'll pull it apart.
