Good Garage In Cambridgeshire
Does any body know where a good garage in Cambridgeshire is, where I can take my Williams 2, and pluged into a XR25X machine. I am being told that this will give reading on what my baby is doing, due to the fast tick-over.
It ticks over at 1000rpm when cold, but once warmed up, it stays ticking over at 1600rpm.
Any help would be great
Del Boy
Mate give WESTS a call on Newmarket Road, or GDI may be able to help you out, i think they are out Caxton way!!
Where bouts in Cambs are ya? Im just out side of St-Ives!!
Hi Mate
Yes I know GDI but not sure if they have this XR25X machine.
I am in Fenstanton mate, just out side of St.Ives also.
Have you tried Wilshers Garage. think its in cambridge (used to be rover) I know theyve got a good RR. might have the machine your looking for.
Im amazed by this, given the amount of clios I see everyday I didnt expect to find 3 other people on the board from my neck of the woods!
Ill have to keep an eye out for a williams in fenstanton (Im from hilton!). Have you tried feltwells at brampton?
Adrian
Im right on thr other side. Royston. There is a bloke here that is a renault mechanic and he can do it.
Sounds like you may need a new temperature sensor, i had a similar problem and when he pluged it into the car it read that engine thought it was 80 degrees all the time.
id ring Andy at GDI, he might not have the XR25 but im sure he can diagnose and fix your problem, he is really good
07010 716440
Adrian
i wouldnt go feltwells, tried rippin me off plenty of times :cry:
tom (s.meadows, huntingdon)
..Ive never had a problem with feltwells. Where abouts you from tom?
Adrian
(EDIT: Doh, just read the bit after your name!)
Feltwells told the bloke who I brought the car off, the injectors need cleaning. Even i know that on a car thats only done 70k the injectors would not be that bad.
I know Andy fron GDI, but let us know brun.
Will have a look out for you Snoop!
Del Boy
Yeah Feltwells reckoned that it would take 22 hours labour to swap my valver engine for my willy lump!!
They are rip-off merchants, everything is almost double what WESTS in cambridge charge!!
Im in Hemingford Abbots, n its good to eventually find out that im not the only from around here!!
I will keep an eye out for you lot n we will have to arrange a meet say in St-Ives or somewhere local!!
cambridge posse!! dont go to wests. bb tuning in essex got a rr! sca in norwich have and all!
yeah im up for meetin up sometime. have to be new year sometime, when the weathers a bit better, after all i gotta polish the car!!
:oops:
Tom
RING ANDY AT GDI !!
seriously he will have that sorted for you before you know it...
07010 716440
del boy
Think we had this chat a little while ago mate, but its either the idle control valve or the temp sender....
I have a spare idle control valve if you want to try it.....
you know where I am if you do.
Andy
