grille off a mk2 ph1
Car  Fabia vRS
I've already searched the forums, but couldn't find anything.
I've removed the 4 torx screws that hold the panel in place, and 'haynes' states that there are clips holding the front panel below the headlight to the wing, but doens't tell you how to access them.
I've already taken out the fogs and tried reaching up from below, and you can't get to them with the headlights in place, which it seems you can only remove once you've got the grille panel off, vicious circle??
Any ideas on how to access the clips that are underneath the headlight/wing joint?? Or remove this panel please?
Jonny
