hey guys when i brake i get this horrible grinding noise but only happenes first couple of times i brake then it goes away. Ive noticed what looks like rust rings around my brake discs. Will i need new discs do you think? :dapprove:
My brakes grind when i first use them till there warm then its gone unless the ABS kicks in then its back again.....new discs and pads going on soon though !
well ie changed the pads hoping that they were the problem and new ones would grind all the crap away on the discs but no such luck. Hmm will fork out for some new discs when i get the spare cash i guess
is this after the cars been stood for a while or overnight? sounds like its just surface rust which is normal. maybe worth measuring the thickness of the discs if your worried.
