Gripper diff - refurb "DIY"
Car  ITB Hybrid+Cup+Scenic II
Hi all,
As I need to strip my gear box due to it constantly slipping out of third gear under accelleration and going over bumps (unfortunately it is not an adjustment issue) I would like to check over my diff at the same time.
After a couple of years use I feel the diff is no longer as "agressive" as it used to be from new.
Does the diff have to go back to Gripper for a refurb or is there anything I can do whilst the GB is out the car and in pieces?
Sending the diff to UK is something I would like to avoid if possible.
Michael
Gripper diffs should go back to gripper every 18-24 months depending on mileage for a service.
This. Mine went back 1000 miles ago, wasn't expensive for a replacement of 3rd Gear synchro and getting the diff "refurbed".
I know you don't want to send it back to the UK, but it's a plated diff and so will need rebuilding. That's why it isn't as aggressive as when you first bought it. Fit a Quaiffe if you don't want to keep sending the Gripper back to be rebuild.
