Grommet Feeding
Can anyone tell if the the grommet based inside the clio 16v\williamss bulkhead is big enough (once removed clearly) to feed 2x power cables. The plan is to have 2 amps, both drawing independent current through separate wires --> battery. im just thinking to myself that maybe the hole is not big enough to run 2 cables through :confused:
Im sure some of you guys of done this, any ideas?
Is it the same one as in the RT? On the passenger side around the footwell? If it is then thats plenty big enough to two big cables through I would have thought, its about 1.5 inches across.
Rick
