H&R Triple C camber adjustment bolts? Anyone?
  Superleggera'd MK3
Hi,
Was just wondering if anyone had ever used these bolts from H&R before? Trying to fix a positive camber issue (big issue) after fitting AP coilovers with my MK3 Non Sport Clio and they DO NOT sell camber bolts for my particular model. They say they should work with any car on the front with a MacPherson Strut (which i think they do....not mechanically gifted so am not 100%).
Any help would be much appreciated guys!
Kieron
  172/1.2/E30
Non sport MK3's have a similar setup as the MK2 Clios, right!? A bracket at the lower end of the strut with two holes which clamps a part of the hub? If this is the case, you can order the camber bolts from H&R. To get the right ones, you'll need to know the diameter of the bolt holes on the strut/hub.
