H/U Losing memory
  Clio 1.2 RT (woo)
Hey, I fitted the stalk adaptor today, which inccidentally works fine, but the H/U (Kenwood) doeskt keep its memory (place in CD, radio presets etc). This happened with my Corsa too, and I had to swap two wires around. Do I need to do the same thing again now, or something else...?
Cheers:cool:
Has
  RS 182 - Black Gold
Sounds like you have disturbed the permanant live.
This is what keeps the radio "alive" when you turn the ignition off etc....
Check the wiring at the back of the HU, also if you have a manual find out which should be the permanant live, and see if its connected and also in the right place.
  Ford Focus ST2
as he said ^^^^
You need to swap (99% of the time it is) the yellow and red wire around!!!
