The bottom of where the drivers seat belt mounts to the car on your right, the left hand side will bolt to the subframe.
At the rear, the seat belt mounts straight behind the seat for three points, for four points, these mounts, and the seat belt mounts at the side of the car also...
You can get a Renault Specialist to turn them off through the Renault Clip - such as Rentech or maybe K-Tec, GDI, BB etc. Alternatively resistors and black tape. Maplins is your best bet.
Depends who you're speaking to. If its Maplins then you need to know where the resistors and electrical tape is. Maybe someone on here like Edde might know the exact resistor you need.
If you're talking to one of the tuning companies i mentioned above then say you've fitted harnesses and you need to turn off the airbag light on your dash and that you've heard it can be done using the Renault Clip system. If they have a brain they'll know what you're talking about.
