Head lamp waher jet not working
Car  GW 200T
Changed my headlamp washer jet the other day on the passanger side. they were working before i took the old 1 off and the bumper. Anmy 1got any ideas why it aint working??
when I replaced my headlight washer I had to hold the stalk down to keep the washers spraying for about minute to get the water back into the system
got the same problem, passenger side headlight washer wont spray but has a constant leak! drivers side works fine. renault quoted £100 to replace jet.
Just need to replace the washer jet bud, common fault. Do it yourself, only £13 for a new one. Renault will have quoted labour for bumper off job but I managed to do mine without taking it off.
My Drivers side doesn't work. A while ago it leaked loads of water though. Does that mean it will be the motor that pumps the water?
Bugger stupid thing has started leaking again, only changed it last May!! Would this part be covered under warranty? If not guess I'll jump down to Halfords and got some 1-way valves
