Head unit & battery
  Clio Billabong 1.2
Recently my car hasnt been starting.
I've figured it's the battery, as when I charge it, she turns on fine.
I think it may be my head unit (Alpine IDA X001)
I don't know if it's been wired up properly, which may leave it running while the engine is off.
I always take the head unit face off over night etc, but even when I do this the battery still goes flat.
Is there a way to check the on/off wiring? What would be making it stay on?
Is there a specific wire which turns the whole unit off when the car is off?
  A shiny black one.
Im sure the headunit won't be running then, or drawing enough power to run down your battery! Have you got a seperate amp and sub set up?
  Clio Billabong 1.2
I have an amp, but one of my speakers has blown so I took the amp out, but the wiring is still in. And that's it.
I don't know what else would be draining it?
  1.2 Dynamique
This happened to me yesterday
I installed an Alpine ida-x300 and then played around with it for a bit and then it wouldnt start!!
