Headlight washer jets - drivers side pipe not ejecting water
GavC
  Black Gold 182FF
Passengers side pipe is being supplied water and ejects water correctly. The drivers side pipe is being fed however when the washers are engaged it isn't ejecting water.
Does this point to the pump needing replaced? If so what's the part?
Cheers,
Gavin
Sent from my Nexus 6P using Tapatalk
  172 Cup
Agreed! I replaced my windscreen washer pump with a 3rd party example from GSF three years ago and it's been flawless :smile:
Gus
  182Turbo,DCi90
biggest tip I can give is to empty the reservoir as much as you can and then label up all the pipes. If you dont label them you will have nightmare with figuring out what goes where.
GavC
  Black Gold 182FF
I got a pair of pumps off eurocarparts the other day much cheaper. They work fine too.
www.renaultpartsdirect.co.uk sell the oem ones.
I replaced my windscreen pump a while back with a eurocarparts.com item. Can you provide part number for headlight washer pump? There is 3 washer pumps available on the site.
Thanks,
Gavin
GavC
  Black Gold 182FF
Replacing the separate headlight washer jet pump under the scuttle panel fixed this
