the mot is due ,found out when I fill washer bottle right up,it leaks(pours) out just under the bumper(passenger side).
the headlight washers do work,but after a few minutes they stop ,because all the water leaked out.
the nozzles are not leaking..
do I try to fix it? or take a chance with the mot...take it in with the water bottle fully empty...I cant fill it up before its tested,cause it will flood the mot station..
if I fill the water bottle half way,the windscreen washers work but not the headlight ones..
