headlights on the blink!! any thoughts?
  clio 172
hi all
on the way home tonight decided to switch headlights on, as it wasnt quite dark enough for the automatic lights to be triggered. after 30mins of driving it was pitch black and moved the light setting back to zero hoping that the automatic headlights would than come on, however i lost the main beam and only the sidelights stayed on i moved the light selecter from 0 to on again a few times but had no luck.
i pulled to the side of the road and switched the engine off left it for a second then started it again and the lights came back on no problems
any ideas folks?
  CB600FS
Are they Xenons?
If so take the units out and leave them on a radiator overnight - water/dondensation etc can get in (time of the year) Mine flickered when it pissed down found water in the ballast re-sealed it and dried them out overnight on the radiater at work aint played up since.
Check your sensor on the windscreen
K
kevr182
^^^^ as tom said mate.......
nice too see sum one else from rugby;)
  CTR--VX220D
This is common.. do a search on Xenon lights on here.
My left one used to go out now and again - touch wood its been OK for the last 2 weeks.
  CB600FS
Chris - How did you cure it mate?
Kev-whereabouts in Rugby you from mate? See more and more RS's everyday no bugger ever waves back round here, bloody peasents :mad:
Might have seen a DCI tearing around quite a bit :eek:
K
kevr182
brownsover mate think i av seen your car around has xenons yeah?????
mines a black 182 with white stripes you mite have seen it around pal.....
  CB600FS
Yeah usually tearing up and down leicester road :eek:
Yeah seen yours a few times theres another lad with a Black 182 with silver stripes - his names Daz
K
kevr182
yeah his has black plates on dont it???? thing i have clocked it once or twice....
