Heater Problem - 172 Cup
  Phase 2 172 Cup
was driving home last night (70 miles) and noticed there was no heat coming from the heaters
turned the air con on, and it got colder!!
fans come on full power, and air con will work
but i cant get any heat
temperature gauge is showing the engine is up to running temperature properly
Chris
  LY 182
to be honest, although its a possibility ive never ever seen a blocked heater matrix before on any modern car.. its always down to something else.
possibly linkage popped off, or theres a flap inside the heaterbox thats known for failing it directs air over the matrix
dash out to do it though
  Phase 2 172 Cup
anything i can take a look at easily?
seems theres no heat coming from it, and there is little cold air today, but colder than when its on full heat
any suggestions??
  Phase 2 172 Cup
just home again
cold air during the whole drive, but when i got home, turned the engine off but kept the electrics on, and i got hot air through it then
its coming on full power, just its freezing, even without air con being turned on
  LY 182
ah, so it works after being stationary a while?
is this the case with it running too. ie after sitting with it running/revving a little while
if so it sounds like a thermostat stuck open and overcooling the engine
  Phase 2 172 Cup
the temperature gauge has been perfect the whole time though
drove home there and it all worked fine, but very little cold ait when i turned the air con on
going to get the pipes tested and gas checked tomorrow and see
