HEEEEEEEEELP!!!
  Golf GTTDI 130PD
Hiya Guys,
Got a problem-just replacedrearpassenger side wheel bearing and hub but since it was put back together theres a grinding noise coming from it.
Any ideas whats wrong???
  Trophy
What makes you think she didnt do it herself?
Bit of a sexist comment to make, Good job your on CSC and not RSC!!!
Mat.
cos if she did it herself she wouldnt need advice! lol
I apoligise, I am all for women working on cars, saves me doing it.
Maybe when theyve taken your rear brake drum off to fit the bearing theyve disturbed a rear shoe are something - sounds like the shoe is grinding on the inside of the drum? its difficult to tell really. thats my guess. Did they use a genuine bearing - part no 7701205812 ? has it been fitted in correctly ? is it the right drum ? take it back and fire the question at them.
jack the back up, spin the wheel.... easier to spot the problem, if its the brakes you should be able to suss it with the handbrake on a bit, more than likely a rogue bearing or something???
