HELP!!!! 1.8 16V Problem
Car  Renault Clio 1.8 16V Ph1
Hi All im new to this so here goes!!
I have a Clio 1.8 16V which up until yesturday has been fantastic!!
I parked it up with no problems come out to it the next day and it sort of started coughing and splutering and not idling particulary well!!
Once its started and its got over its miner hicup! it runs 100% cold/warm until u switch it off!! When u then try to restart it when its warm it then turns over fires once and fails to start!! u then need to crank it over for about 15-20 secs and it fires up fine with no probs!! ANY IDEAS? i havent a clue!!
Please Help!!!! Thanks:(
the engine coolant temp sensor is a very common fault (as are a lot of things lol)
i had a bad coil on mine which caused a starting problem, however it didnt affect the running of the car at all
i did have a misfire problem with a heavily corroded dizzi cap and rotor arm
the engine position sensor as mike has mentioned, can cause all kinds of problems if faulty
sadly the idle speed control valve is a common problem aswell however you can take this off and clean it with carb cleaner and WD40
Hi thanks for your help
Which sensor is it (what does it look like) there are 3 in that area that i can see!!
please advise? Thanks
Cheers mate! Probably change mine cus ive dun everthing else still aint quite right!
Amir
Thanks guys look into it tomorow. Got a serious rear wheels bearing issue at the moment :(
Is this the same as the crank shaft angle sensor?? or diferent? can i get it from GSF?
Amir
Yeh euro car parts job!!! Did u know dan that fom renault the CTS is nearly £60!!!!!!!!!!!!!!!! and from Euro car parts its 10 sheets! Scandalous!
Thanks anyway dan 2 bolts then!! dead easy i hope!
Thanks dude!
Amir
