Help 172 major problems
  Clio 172
Hi all ....great forum by the way:)
I dont know where to start:S
i have owned my 2003 clio 172 for almost a month now a couple of days ago
my stop and battery light came on(flickering).then yesterday esp,airbag and
abs lights came on,then today the car wont start at all when you turn it over
it just clicks(no turn over) and the petrol and temp gauge just goes up and
down.....i did manage to start it after using jump leads but 5 or so
mins later it died and will no start.
any help would be appreciated:dapprove:
  Clio 172
Many thanks Gobsheene m8 will be buying one in the next 30 min or so.
will let you know if it has worked
  197
you should have borrowed one out of your mates car to see if it actualy was the battery first.
hope it fixes the problem
  Clio 172
thanks all..changer the battery and it started first time however the only lights on
now are the stop and battery:dapprove:........does it need to be reset or is
somthing else wrong
ps
plus now need stereo code
  RB FF 182
Check that the + cable to the alternator hasnt snapped off at the terminal, this is quite a common fault afaik.
It was the only time that I got those same error lights up on my dash.
Sash
  A Yellow One
Go to your renault dealer with log book they should give it to you.
Da
  Less
MATT BLACK on here can provide codes for the radio, do a search he has a thread somewhere.
  Clio 172
I phoned them earlier and they want £15+ and insurance + logbook
and another form of identification.....may as well throw in the Wife as well:rasp:
