HELP:car not performing can hear a ticking noise?
  clio rs
NEED HELP:
just took the car for a spin, reved it at 1st gear and the car didnt perform
and it made a ticking noise.
Does anyone know what could be the problem, its due a service which is booked in for the 16th sept at a renault specialist.
i check the car were was not much oil.
its i can still drive it slow, but did cut off a few times.
does any have an idea what the peroblem could be?
  Dodgy one
Was it checked cold or hot, Not all the oil will be up in the sump if warm, I picked up an EOS from a site for work which wasnt registering on the dipstick and that was fine.
Also ran mine just above min and it made a tapping noise, Filled it up and it cured it, Now as i hardly use the car its tapping again, Flushed it still there, Lifters clogged me thinks b****cks :( Think i've read here they're about £20 but have to be done with the cambelt, Luckily mines due so can have it done then :)
  clio rs
i was low a month ago, i topped it up with alittle £10 bottle. I need to drive the car to a local specialist like markfish or ren7oaks. If i top it up will it be safe to drive. Do specialist have RAC that customers can use
