*HELP*Clio instrument dials electrical problem
All
Car was broken into a little while ago and the dash was taken apart and the instrument dial panel looms were cut of. The car does not start or anything. It seems when the car was broken into and the looms cut, it short circuited something as it blew a few fuses as well. I was wondering if any one could advise if the wiring loom itself for the instrument panel can be purchased or if the whole loom will have to be replaced.
Thank you for any help
1.216v 2001 Clio
The loom for the dashboard is much the whole internal loom anyway.
Its not cheap.
Get trying to fix the wires up yourself you should be able to work out which are which.
