Keith185
Fault light came up this Morning. Connected my rstuner up to it now and has come up with following fault
Fault Code: DF0092/DF0967
Description:O2 Sensor Front
Had a look at the live sensor reading/values and the Front O2 sensor voltage fluxuates loads (below and under the min/max value) even on idle while the rear one stays on max value? I can't clear the fault, assuming because of it going under/over the value?
Car seems to still run fine. Is this deffinately a fault in the front O2 sensor and how urgent is it to replace?
Where is the front one located? (car on side of street, unable to jack up grrr)
