Help needed.....
Car  1.2 extreme, now in bits
As im driving along there is what i would describe as a 'knocking' sound coming from the back left of the car, this dies down after a minute or so of driving then re-appears as i turn right but only when turning right, not left?
Any suggestions??
could be, was checking the suspension myself (pusing down on it) and it didnt seem to be making a noise or look abnormal. Wheel bearnings pricey to get fixed?
could be lots of things - wheel/bolt problem, hub/bearing, damper, spring, beam bushes, arb(?), exhaust loose
you'd have to put it up on a stand and have a good look, testing various bits unless the cause is obvious
should've added in my first post that you can hear the wheel like it is almost rubbing off something (it's not though, i've checked that) but you can hear it rotating if that makes sence?
