HELP Omp subframes sit wonky
  ly clio 182
Have a set of omp sub frames sit pissed. Looks like the side of the subframe closest needs to be raised about a inch or dropped on side closes to the door a inch.
Has anyone else had the same trouble I have been looking but no real answers.
Can I cut and 're weld as don't want to pack with a inch of metal
Please help.
  BG 182
Yeah they are on the piss mate if you spend the time you can get them level with spacers.
I just bought the custom frames of @JON FOZ they sit perfectly and are a lot lower no spacers needed or anything
Rubicon_
  Defender 110
Yep mines meed raised at the gearstick side on both around 2cm.
You can either get spacers machined or use some thick washers.
  ly clio 182
Thanks for the replies guy.
Saw Someone had it there's is this possible. I'm around a inch out. So maybe packing is a option. How much were the ones from John ?
  Clio 182
Had 23mm chopped off of both subframes on the door side and re welded back together, didn't want to be packing out a seat mount ....God knows why OMP haven't corrected the issue.
