Help on enginebay cleaning?
Hi all..
Looking for a bit of advice/tipa on cleabing my engine bay?
Standard 172 with standard filter and everything else so theres a fair bit of dull plastics and a dirty inlet etc.
I dont want to get a hose or anything on it incase the worst happens so im just wobdering how i would go about tidying it up a bit? Cheers!
A diluted all purpose cleaner orator glym engine and machine cleaner worked in with a small detailing brush, then lightly rinsed or wiped clean. Black plastics once cleaned use a trim dressing, such as autofinesse revive or autoglyms offering
Cold engine, spray on some all purpose cleaner (Megs APC, G101, AutoGlym Engine and Machine Cleaner), aggitate with a couple of detailing brushes, ideally rinse on a low pressure, but if you're worried, damp cloth and wipe over.
Treat the metal as you would your exhaust (metal polish), the painted sections as you would your paint (polish them up and apply high temp sealant) and plastics, look at something like 303 Aerospace Protectant; http://www.cleanyourcar.co.uk/interior/303-aerospace-protectant/prod_366.html
Thanks guys! I bought some GUNK to try and help a bit but its not done too much! Ill try and get some of the products you mentioned! :)
I'm just starting to clean mine up mate, but im not using water on mine either.
Giving the underside of the bonnet a good clean is a good start, that's what ive done, got to start giving the rest a clean up now! Need to get some brushes too.
