Help: problem with my trophy seat
Car  clio rs
as i was driving, my seatbelt got court with the adjustable nob. The nob got pulled, now its sticking out, and i cant get it to go in.
also when i tried to pull the recliner, it was very stiff and the seat was not going forward, as i pulled force it snapped...
please help can i fix it, the nob has not go in.
also be even better if someone came to have a look at it.
You have pulled the lever out of the mechanism.
That little plastic lever is £30 from renault;)
Sit in back, shine torch into area, you wll see a metal lever will have popped out of alignment. Look at other seat for reference.
If seat won't lock into place fully this is the cause.
ill take a look, i pulled it too hard and it snapped, do u think the whole thing is a easy fix..no one has taken a look at it yet, as i dont know who u got to
10 mins to fix.
The plastic lever slides onto a metal bar.
The metal bar then locates on another there is your problem.
By looking at other seat you will see exactly what you need to do.
Srewdriver to prise bar back into correct position;)
Thanks dude, i gave it a go and it worked, its now sorted, all i need now is the leaver from renualt £30, but i think that can wait. Thanks again steve your a credit to cliosport.
