help!! putting my hub back on.
Car  mk1 phase 3
right, just had my wheel bearing changed and am trying to put my hub back on! everything is done apart frm the bolt that points upwards going through the stalk coming off to the left of the brake disc, think its the track rod end or somet?! anyway, the nut goes on so far then the bolt just starts spinning, did the other side aswell, but i just clamped it with grips and was ok, but doesnt want to do it this side, any other way of getting the nut on?? thanks:)
You have to get a jack under the bottom of the ball joint and jack it up to apply lots of pressure, thats the only way to stop it spinning.
