HELP! Starting to get pi55ed off!
Car  E60 diesel powah
Right coilpack got changed today,however car still cuts out?! WTF!
Changed it this morning, been driving mint all day, until now it cuts out and doesnt want to start?!!?!? HELP!
yup! however the coilpack did need changing as that was a problem first, me thinking that the coilpack would be the solution to all of it..was completly wrong lol
The coilpack isn't the cause of your car cutting out then , check your spark plugs , have you changed the leads as well ?
yup, leads n coil pack, plugs were changed about 3months ago! As said, it will cut out, and will not start! i have to disconnect n reconnect the coil pack! :@ gash
Do you still get injection events when cranking, post coil 'shutdown'?
You'll need to isolate it to a macro or micro problem.
dodgy map sensor connection?, check the pins inside the loom plug...
if the connection breaks it just kills the car and will stall... run fine.... stall etc
