help with brakes
  1.8 rsi
i have just brought some 1.8 16v calipers for my clio but dont know what size disks i need to go with them some one told me on here that there 259 mm disks i have just got some and they are to big they dont fit inside the carrier thanks dale
Are you sure you have the right caliper bracket as the R5 GT uses the same caliper bracket but uses a different brackter as it uses the smaller 239mm disk.
You need 259mm disk for a correct 1.8/williams etc brake setup
  1.8 rsi
could be bud the brakes were apparently from a williams its the thickness of the disk thats the problem they are to thick i got a feeling they could be for a megan
