Help with calliper needed pls
  Clio Sport 182
I recently purchased a refurbished rear calliper for my Clio Sport 182, however, it seems that I wasn't sent the correct calliper. It looks indentical to the one I need to replace except for the where the handbrake cable goes. Has anyone else had this issue?
haimsey
  ph2 172
Just make sure the arm that holds the cable looks like solid round bar bent at 90*. I recently bought an item that had more of a flat cast looking arm. Turned out to be a crappy copy job
  Clio Sport 182
Thanks for the reply.
I got a friend at a local garage to drill it.
However I still have a a very stiff brake pedal with very little brakes, any idea what the issue could be?
haimsey
  ph2 172
Maybe an air bubble in the system? My issue I had was that the calliper was seized so wasn't working properly
