Help with cam timing
Car  Clio 182
Hi guys,
Im currently carrying out a cambelt change on my 182, it's all pretty straight forward and I'm using the Renault tools.
I have slaken the pulleys off to tension the belt, then you tighten the pulley locking tool to allow you to tighten the pulleys back up, however, everytime I try to do this, I can't tighten the tool without it moving the pulleys around slightly, which is going to mess up the tension again?
How do you get around this? Or is it just peserverance?
Forget it, just had another look at the ends of the pulley locks, you can get a spanner on there to stop them moving.. Embarrassing.....
