Help with wiring!!
Got amps wired up fine and 1 of thems running a set of 6x9s.
2nd amp as power and all connections are good but i cannot get the subs to work.
4 channel amp, Im an ice amature so dont know my technical stuff, so i drew a couple of diagrams!!
Plz help is driving me mad!!
  Polo + Micra
take the link off the sub that is acting as a dead short(top one in pic)
what is the resistance of the coils of the sub??
it needs to be wired to 4 ohms to run it off the bridged channel of the amp
  Polo + Micra
aw1251T?
[FONT=Arial, Helvetica, sans-serif]12” NATURAL SOUND WOOFER
45 oz. Strontium Magnet
Power Handling: 400 watts RMS
Frequency Response: 24Hz - 1kHz
Efficiency: 92.1 dB
PHAT Foam Surround
Non-Pressed, Non-Transfer Paper Cone
KM3’ Coated for Virtually No Cone Distortion
2” 4-Layer ASV Voice Coil
Dual 4 Ohm
2 or 8 Ohm Operation
Mounting Dimensions: Depth; 5 1/4”
Hole; 10 7/8” Diameter; 12 1/2”
MULT-CONNECT Lug Lock Terminals
if so you can wire them to 8 ohms but thats not ideal
[/FONT]
  Polo + Micra
yeah wire it to 8 ohms + from amp to +on voice coil 1 then a wire from - on voice coil 1 to + on voice coil 2 then - on voice coil 2 back to amp
then connect the wires to bridged across ch1&2
repeat for other sub but use ch3&4
