Hesitation/juddering under load at low speed.
Paddy_g46
Following from the other thread in this section I posted. Another problem he seems to have is that the car judders or misfires maybe when trying to pull away at low speeds. For example, I drove it and when you are in 3rd gear at 20mph and you put your foot down the car stutters for 1 or 2 seconds and then takes off and revs fine through the range. It only does it at low speed when in a slightly high gear (under a heavy load)?
I wasnt sure at all what this could be as the car revs/drives fine apart from this!
Any ideas?
