High Oil Temperature
not really.
probs really really dirty coolant system.
Mine runs high and looses pressure as a naturaly......but thats at about 5000rpm 115 deg etc etc.
when was the oil changed last? if it needs a top up, then top it up! I work on the theory that less oil is gonna get hotter or you could have a dodgy sender!
It was changed when I came to the uk about 3 weeks ago, it ran slighty hotter when I was on the motorway come to think of it, would that be down to the higher speeds? The oil level is fine
Will probably be down to a change in oil - but high oil temperatures are usually associated with increased friction somewhere.
oh here comes the shady jokes! :)
Right ive used the words fooked, head, and hotter lets see what wonderful combinations you can come up with ;)
