UPDATE.
Well, I'm a bit unsure as to where I got to really. The house is coming along, first and second floor are nearing completion so will be able to start hanging televisions soon enough.
Lighting racks are now all wired up, finding the control loop of cables was a bit of a mission as half the house isn't built yet as the pool room has had to be taken down and rebuilt so there were open cables everywhere. Having found all those now we have our full control loop and keypads have started going on the top two floors.
Also been able to terminate plates on the top floors and clean areas on the ground floor. Anywhere where a TV is to be installed we are using a brush plate so cables can come out behind television freely with no kinks or extra joins, the ones below have been pushed into the void!
Speakers have also gone in on the top two floors, this is a Bowers & Wilkins CCM664SR speaker which is a stereo speaker in one unit, mainly used for small rooms such as bathrooms. This is the first part and then the speaker is put into the frame.
And then the final look, in a different room, using Bowers & Wilkins CCM663's.
That is as far as I've got with pictures, but most Cat6 terminations have now been done in the rack downstairs, with exception to areas that have no sockets yet due to the rooms being at a different stage, the basement has only just been plastered. We also fitted all the high level CCTV cameras during the week which are now up and running. We're now ahead of ourselves there in all honesty until the place is a little cleaner. Ideally looking to start installing equipment in the first rack so we can get the rest downstairs!
In other jobs recently, this week we fitted a 65" Panasonic plasma into a wall. The wood panel goes backwards and up and then the television moves forward flush with the wall.
C+C+Q welcome!
