Hot Hott & Hotter !!!!
Car  1*4 phhslow
hiya was wondering if anyone else has had this problem really strange went round a roundabout the other day and all off a sudden my car started heating up rapidly going even going down the a12 with all the the speed it still heated up only way i can cool it down is to wack my heater on hot and on full blast !!!! thats not nice either lol but has to be done other wise i think somethin will break ???
Any help will be gratefull dunno wether the temp sensor has gone or i need to flush my system ???
PLease help :)
Many thaks tom
that is what i am hopping it is ... only other thing is i have a lot of white spray all in my engine up my induction hose and on the fire blanket on the bonnet no idea what it is .. how much for a thermostat ??
Try track down the source of the white spray. Might just have been from when it over heated but look to see if its coming from around the cylinder head. Also check the inside of your oil filler cap for 'mayonnaise'. This is the creamy yellowy/white emulsion you get when water is managing to get into the oil system somewhere.
Have you noticed your coolant level dropping and needing topping up at all, did you have to put anything in after you noticed your overheating problem?
WHen checking for the above "mayo" on the oil cap, just bare in mind a small smithering of discoloruation can be perfectly normal. Its just condensation/vapour mixing with oil splashes. Your looking for something thats alot thicker....you will no when you see it.
Secondly all those splashes could indicate one of your pipes has either slipped off, or is not sealed properlly. Start the car, get it to operating temp by holding it at 2000rpm and then go look in the engine bay, see if you can spot a leak from anywahere around the rad to the block.
Keep an eye on the coolant bottle, look for signs of bubbles in there surfacing. Make sure the level of the coolant is between min and max when cold and rises to max when hot.
thats the point nothing happens in my coolant bottle doesnt boil or anything and i think becasue i have a circle of the white spray on my fire blanket its prob spray wax from the polish people cleaning it and sparying it up my cold ait feed maybe ... no no mayo stuff under the oil cap ... i get a new thermo tomorrow for a £10 so will fit that are they easy to do ??
how do you no how much coolant to drain before i take the pipe off to the thermostat as i dont want to get soaking wet lol ???
