passenger footwell, look up, there is a large rubber grommet, remove this (will need to remove bonnet release cable), drill hole sufficient enough in grommet then feed cable through
interior, you can slip the wiring under the interior trim, but for best results it is best to remove the trim and feed cable into the guide clips
remove rear seats then slide through, replace rear seats, cable is in boot, do the same for the RCAs and remote cable - with the exception that they come from the head unit not the engine bay
